A microservices architecture breaks an application into small, independent services that each handle a specific function and communicate through APIs. If one service fails, the others ideally keep running instead of taking down the entire application. It makes systems more failure-resistant, but only if those microservices are designed to fail safely.
Microservices best practices help you control how your services depend on and communicate with each other, so a failed API or unavailable database doesn’t trigger a chain reaction.
Define clear service boundaries
When designing microservices, decide where one service stops and another begins. A useful rule of thumb is to draw those boundaries around a distinct business capability.
Domain-driven design is a practical approach to draw boundaries. It groups related business logic into a bounded context, or a defined part of the business with its own rules, language, and data. The single responsibility principle is also useful — each service should own one business capability rather than sharing that responsibility with others.
For example, an order service might take care of order creation and each order’s status, while a payment service handles charging and refunds. Keeping those responsibilities separate also makes each service independently deployable, so changing your payment logic doesn’t require you to release unrelated parts of the application.
If different services share the same responsibility, even a small change might force you to update APIs, move data, and coordinate deployments across all of them.
Build resilience into service-to-service calls
As your services start depending on one another, service-to-service communication becomes part of your potential failure surface. A service can be healthy and still fail to complete its task because another one times out, rejects a request, or becomes temporarily unavailable.
With synchronous communication, one service waits for another to respond, so a slow dependency can delay the caller even when the caller itself is working normally. If you don’t need an immediate response, asynchronous communication can reduce that dependency. For example, one service can place work on a message queue for another process when it’s ready.
Designing for these failures is a core part of distributed system resilience, where the wider system can keep doing its job even when one dependency has a problem. That’s why you use microservices architecture patterns like circuit breakers, retries, and bulkheads. Each addresses a different failure mode.
Circuit breaker pattern
A circuit breaker watches for repeated failures and temporarily stops sending requests once they cross a threshold. It doesn’t repeatedly wait for a service that’s unlikely to respond, but instead it lets the caller fail fast for a period and gives the dependency time to recover.
Retry with exponential backoff
Some failures are only temporary, so if a service times out for a few seconds, trying again may be enough to complete the request. Retries make sense for transient faults, like timeouts or rate limits. However, retrying immediately can put pressure on a struggling service.
Exponential backoff handles this by increasing the delay after each failed attempt.
Bulkhead pattern
A bulkhead pattern isolates one failing part of your system and prevents it from consuming resources that other tasks depend on. For example, if Service A becomes unresponsive, requests to Services B and C can still use their own resources.
Route traffic through an API gateway
As your service count grows, letting clients call each microservice directly can create coordination issues and become difficult to manage. Every client has to know which endpoint handles its corresponding request, and changes to a service can force changes in the clients depending on it.
For example, imagine a checkout app that has to know all the separate URLs for:
- Orders
- Inventory
- Payment
- Shipping services
If one of those services moves or changes its API, you may also have to update every client that calls it.
An API gateway pattern solves this by giving clients one entry point. The gateway receives a request, decides which services should handle it, and forwards it to the right place. It keeps the internal structure of your system behind a stable interface, so you can change or reorganize services without exposing every change to the client.
The gateway needs to be constantly available and resilient itself. If every request passes through one gateway, that instance can become a new single point of failure. You can tackle this by using multiple instances or regions and using load balancing to direct traffic through another gateway if one becomes unavailable.
Make failures observable across the system
Finding the failure source becomes challenging in a microservices architecture because one request can cross multiple independently running services before you notice the final error. For example, if a checkout request moves through inventory, payment, and fulfillment, a failure at the end doesn’t immediately tell you which service caused it or what happened to the data along the way.
In monolithic architecture, where most application logic runs inside one larger app, you can often trace the problem from one set of logs. With microservices, you can use distributed tracing to follow the same request across services and centralized logging to bring their separate logs into one searchable data store.
n8n is an AI-native, source-available workflow automation platform that can orchestrate calls across APIs and services in visual workflows, with code available when you need custom logic.
n8n allows you to improve visibility across your project’s microservices. For example, after receiving a Redis event, n8n checks whether the services work within acceptable error rates. If so, two related microservices are called sequentially and the Redis key is removed. If one of the microservices fails, an Error Key is incremented: If there are too many errors within a pre-defined TTL, the workflow stops with an error.
It offers visibility across parts of the process it orchestrates. In the Executions view, you can inspect previous workflow runs, follow the path an execution took, and check the inputs and outputs at each node to see where data changed or a call failed. You can also load data from a previous execution back into the editor to debug and rerun it.
Make resilience part of the architecture with n8n
Resilience is most effective when you design for failure proactively. That means deciding how your services communicate, where failures should stop, and how you’ll identify and understand what happens when a request doesn’t complete as expected.
n8n can complement that architecture by giving you a visible orchestration layer around your service calls. Your microservices still own their business logic and infrastructural resilience, while n8n coordinates the workflow between them through HTTP calls, branching, retries, and failure handling where appropriate.
As those dependencies grow, it might be helpful to explore n8n’s guide to event-driven microservices.
