Open-source tools provide code visibility. They don't guarantee encrypted credentials, scoped access, and continuously logged actions. While they can have the governance and security capabilities you need, features vary from platform to platform.
This guide compares open-source workflow automation software on deployment model, secrets handling, access control, and auditability.
Why businesses need open-source workflow automation software
Teams adopt open-source workflow management for two main reasons: control and flexibility. You get the governance to run software on your own terms, and the freedom to bend it around processes a closed SaaS tool doesn't accommodate. But it goes deeper than that.
Cost effectiveness
Open-source workflow automation removes the per-task and per-seat billing that makes closed platforms expensive at scale. You trade a subscription for infrastructure and engineering time. This can be beneficial once volume climbs into the hundreds of thousands of executions, but it may not be worth it to a five-person team running a handful of workflows.
Customization and extendability
With open-source software, you can read the code, fork it, add a node for an internal API, or drop raw JavaScript and Python into a workflow when the visual builder runs out of room. Closed tools cap you at whatever the vendor exposes; source-available and OSI-licensed platforms let engineers extend instead waiting on feature requests.
Community support
Open-source tools often have a large community, which is free QA and a living knowledge base. Popular projects ship integrations faster, surface bugs sooner, and leave a trail of forum answers for edge cases. Smaller projects can be sharper technically, but they leave you closer to the source code when something breaks.
Scalability
Owning the deployment means you scale on your terms horizontal workers, Kubernetes, auto-scaling rather than waiting on a vendor's tier limits. Most modern engines separate scheduling from execution, so you can add capacity exactly where the load lands.
Security
Open source tells you nothing about security on its own. Transparency lets you inspect the code, but it doesn't configure encryption, scope access, or stream an audit trail to your security information and event management (SIEM) platform. Assess workflow automation security across five dimensions:
Best open-source workflow automation tools
Open source' doesn't mean the same thing across every tool, and the gap shows up the moment legal reviews the license. Here are the distinctions between our listed tools:
- n8n is source-available under its Sustainable Use License.
- Activepieces (MIT), Temporal (MIT), Apache Airflow (Apache 2.0), Kestra (Apache 2.0), and WKS Platform (Apache 2.0) are permissively licensed.
- Windmill uses copyleft AGPLv3.
- Camunda 8 now ships its self-managed components under a source-available license, paid for production use.
The table below scores each tool against the same five dimensions:
| Tool | Deployment | Secrets | Access control | Audit logs | Codebase model |
| n8n | Self-host / air-gapped / cloud | Encrypted store | RBAC (paid plans), SSO (Business+) | Stream to SIEM (enterprise) | Source-available (SUL) |
| Apache Airflow | Self-host anywhere | Backend / connections | RBAC (coarse) | Task logs, external | Open source (Apache 2.0) |
| Activepieces | Self-host / cloud | Encrypted store | RBAC, SSO (Enterprise) | Audit logs (Enterprise) | Open source (MIT) |
| Windmill | Self-host / cloud | Built-in secrets | RBAC; SSO | Audit logs (all tiers, extended on Enterprise) | Open source (AGPLv3) |
| Camunda 8 | Self-host / cloud | Connector secrets | RBAC; SSO | Audit logs | Source-available, paid in prod |
| WKS Platform | Self-host / cloud | Kubernetes Secrets (bring your own vault) | RBAC; SSO via Keycloak (OIDC/SAML) | Audit trail | Open source (Apache 2.0) |
| Temporal | Self-host / cloud | Per-namespace | RBAC; SSO (Cloud) | Audit to SIEM (Cloud) | Open source (MIT) |
| Kestra | Self-host / cloud | Namespace secrets | RBAC; SSO (enterprise) | Audit (enterprise) | Open source (Apache 2.0) |
1. n8n
n8n is for teams who want a visual builder without giving up engineering control. Its node-based canvas supports both deterministic and agentic execution, so you can pin a workflow to fixed logic or hand steps to AI agents all in one place. Execution history and the Insights dashboard give you immediate visibility into what your agents do, and you self-host on your own infrastructure air-gapped if you need it or use n8n Cloud. Credentials stay in encrypted secret stores, and log streaming sends an audit trail to your SIEM on Enterprise plans.
Custom JavaScript and Python nodes extend it wherever the 1,000+ integrations stop, and AI agents can call external apps and services as tools, either through dedicated tool nodes or by wrapping any workflow as a sub-workflow tool. Keep in mind the Sustainable Use License allows full use of n8n for your own automations, but not for reselling it as a hosted service.
2. Apache Airflow
Apache Airflow is the data engineer's default: Apache 2.0, battle-tested, and backed by a reliable orchestration community. You define workflows as DAGs in Python and lean on a large provider ecosystem for integrations. Airflow 3.0, released in 2025, modernized the execution model, but the tool still shows its origins. It's built for scheduled data pipelines, not general business automation, and its RBAC is coarse enough that hard team boundaries often mean separate deployments.
For a deeper comparison of n8n and Airflow's execution models, see our page on n8n versus Airflow.
3. Activepieces
Activepieces is permissively licensed via MIT, allowing freedom and simplicity that appeals to legal teams. Its visual builder and 700+ pieces make it a solid self-hosted workflow automation tool for non-developers. The open core model means some governance features live in paid tiers, and the integration library, while growing fast, trails n8n in integration breadth. Choose it when ease of use outranks depth.
Both n8n and Activepieces support self-hosting and visual workflow building. Where they diverge is AI agent orchestration, integration depth, and enterprise governance — covered in detail in n8n versus Activepieces.
4. Windmill
Windmill focuses on performance. Its Rust engine runs scripts in multiple languages including Python, TypeScript, and Go, and benchmarks well against heavier orchestrators. You get built-in secret management, RBAC, and auto-generated UIs from your code. Two caveats: SAML SSO and advanced audit features sit behind a separate enterprise license, and the AGPLv3 license is genuine copyleft. This means building a product on top of Windmill can force you to open-source your own code or buy a commercial license.
5. Camunda
Camunda is the enterprise process orchestration heavyweight, built for BPMN-modeled business processes in the Java ecosystem. Camunda 8's Zeebe engine is cloud native and scales across Kubernetes for microservices architectures. Be sure to read the license closely: Since late 2024, the self-managed components ship under the Camunda License, free for development but requiring a paid license in production. Camunda 7's community edition was Apache 2.0, but it reached end of life in October 2025 with no further updates or security patches. Camunda 8's paid production license is now the only actively maintained path.
6. WKS Platform
WKS Platform is an Apache 2.0 case management and workflow stack for teams that need BPMN process automation alongside adaptive case management. That covers long-running cases, approvals, and work that doesn't follow a fixed path. It's self-hosted, on-prem or in any cloud, with RBAC and audit-grade case history, and it offers a migration path for teams coming off Camunda 7's community edition. It's built for structured, long-running business processes rather than app-to-app integrations, so it fits best next to a general automation tool, not in place of one.
7. Temporal
Temporal is not a visual tool — it's a durable execution engine for code-first teams. Its MIT-licensed server is free to self-host, and you write workflows directly in Go, Java, Python and TypeScript with automatic retries and state recovery baked in. That makes it the right call for long-running, mission-critical workflows where a dropped step is unacceptable. It may be an overkill for simple task automation, and most governance features such as namespace RBAC, SAML SSO, and audit logs live in Temporal Cloud.
Check out our breakdown of n8n versus Temporal to compare these tools in depth.
8. Kestra
Kestra is a modern, Apache 2.0 alternative to Airflow that swaps Python DAG boilerplate for declarative YAML. Flows are reviewable in a pull request without anyone needing to read Python, and namespace isolation scopes access control and secrets per team. Enterprise adds SSO and audit logs. With 1,700+ plugins, it covers the same data integrations as Airflow, but it's lighter to self-host, though its JVM-based engine is more memory-hungry than Node.js or Rust alternatives, so plan for at least 4 GB of RAM.
Top evaluation questions to ask yourself
Here are some straightforward questions to help determine if a tool fits your needs.
Can the platform run entirely on our infrastructure?
Look for self-hosting with no mandatory cloud callbacks, plus an air-gapped option if you're in a regulated sector. You control data residency only when execution and storage stay on hardware you own, configured through the environment variables you manage. Most tools here support self-hosting; Camunda 8 self-hosts but needs a production license.
How are API credentials stored and isolated per workflow?
The right answer is encryption at rest and access scoped by project and role, never plain-text secrets in the workflow definition. n8n keeps credentials in encrypted storage separate from workflow logic, with access controlled at the project level. Plain-text secrets in workflow definitions are less common among modern tools but still worth verifying.
Does it support SSO with our identity provider?
SAML or LDAP integration lets you enforce MFA, session timeouts, and deprovisioning from one place. Treat SSO as table stakes for any deployment past a handful of users — though note that in several open-source tools, including n8n, it sits in higher-tier paid plans.
Are audit logs streamable to a SIEM?
Compliance reviews want immutable logs you can forward to your existing SIEM, not screenshots from a dashboard. Confirm the tool exports structured events such as workflow runs, credential changes, and permission edits over a secure transport. n8n streams these over transport layer security (TLS) — check whether your shortlist matches that before procurement asks.
Gain control and visibility with n8n
An open-source license tells you what you can do with the code; it doesn't specify encryption, scope, or records. You'll need to evaluate those independently. If you want a visual platform that brings enterprise governance without slowing your builds, n8n covers both.
Browse n8n’s workflow templates and cybersecurity integrations to see how the pieces fit your stack.
