“Claude Code or n8n?”
I get this question quite a lot. Sometimes it’s at an event, or a question from a co-worker, or just someone who saw a YouTube video and wants to know if they should be worried.
I work in product marketing at n8n, and I also spend a lot of my time inside of Claude Code, so I can see both sides.
Unfortunately, I can’t give you a direct answer, for two reasons:
  1. I don’t think that’s the right question to ask.
  2. It’s not one or the other.
It’s kind of like asking “should I hire a world-class chef or a catering company?” The answer is: it depends. Maybe one, maybe the other, and often it’s both. It depends on how many people you’re trying to feed, how often you need to make a meal, and how different the meals are going to be. You get the point. At the end of the day, the best catering companies work with world-class chefs.
Let me get something out of the way first.
Whatever you end up building, regardless of what platform you’re building it on, you should definitely be using AI to help you build it. Once you get used to having AI convert your ideas into what you asked for, you never want to go back to building things from scratch by hand.
If you’re already using n8n, you should definitely be using Claude Code (or Codex or something similar) together with n8n’s MCP server to do most of the work for you: creating, editing, testing, and managing your workflows. We even have official skills that help Claude Code do it well.
The official n8n MCP server added these capabilities fairly recently and a lot of people are still not aware of this. If you only take one thing away from this article, it’s that you should definitely be taking advantage of the official n8n MCP server when building workflows in n8n. By the way, it keeps on improving.
Getting back to the question itself, I want to break down what “build it with Claude Code vs n8n” actually means, because I’ve noticed it means different things to different people:
  • Using Claude Code purely as an AI agent. Give it plain-English instructions, and it simply executes those instructions. This is what I would call a pure AI agent.
  • Using Claude Code to build software using a programming language: TypeScript, Python, or whatever you prefer. The software it creates is what’s going to solve your problem.
  • Building a workflow in n8n. This should be pretty self-explanatory: a workflow with some deterministic steps and some AI steps, where it’s up to you to decide what the overall process and structure looks like.
These three options behave differently when it comes down to costs, complexity, requirements, etc.
I’ve found that figuring out the best solution for your specific needs usually comes down to answering the following five questions:
  1. What’s the process you’re building?
  2. Who makes the decisions, and when: deterministic rules, the AI, or you?
  3. Who’s involved: building, maintaining, using it?
  4. What does it take to run reliably: where, when, and at what scale?
  5. What are the consequences when something goes wrong?
Let’s break each one down.
The first question is: what are you trying to accomplish?
For example:
  • “I want AI to automatically respond to incoming support emails.”
  • “I want AI to monitor my competitors’ websites and let me know what they’re up to.”
  • “Every time someone fills out our demo form, I want them researched and added to our CRM.”
That’s the level to start at. Once you have that one-liner, break it down into more detail. Here are some example questions:
  • How many systems does it need to connect to, and which ones?
  • Does it need to remember things between runs?
  • Does it need to respond in two seconds, or is ten minutes fine?
  • How different will the process be from run to run: the same steps every time, or does it depend on what comes in?
At one end of the spectrum, you’re building an actual piece of software: an app with a UI, a product, a tool with custom logic and no AI inside of it. If that’s what you’re building, use Claude Code and a programming language. n8n was never meant to be an app framework.
At the other end of the spectrum, you’re connecting existing systems to each other: when a form is submitted, update the CRM, notify the sales channel in Slack, and add a row to a spreadsheet. Most of the work here is plumbing rather than logic: credentials, authentication, API quirks, and rate limits, multiplied by every system you add.
The underlying question is: how custom does this really need to be?
Sometimes the answer is “very,” and building from scratch is right. But most of the time, it makes sense to use a solution that was built for exactly this type of work, because it takes care of everything you’d rather not deal with.
Software engineers know this trade-off well: you could write your web app without a framework like Next.js, and sometimes you should, but most of the time someone else already solved the boring parts.
Every process has decision points.
The second question is about who (or what) is making those decisions.
Some processes need no judgment at all.
Move every invoice from Gmail to Drive, every day, the same way. If you can write down rules that cover every use case, then nothing about the job needs AI while it runs. Make it deterministic: the same behavior every time, at almost no cost per run. Paying an AI to re-decide something you already decided is a waste of tokens and money, and worse, it introduces the possibility of a different answer on run 79.
Some processes are mostly judgment.
Researching a topic, writing an article, cleaning up a messy one-time dataset. There’s a lot of back and forth, you’re steering, and each step depends on what you thought of the previous one. That’s a pure AI agent situation, with you in the loop, and wrapping a workflow around it usually adds nothing.
A lot of the interesting processes are in between.
The process repeats, but there’s a decision inside of it. Support tickets are my favorite example. Five hundred tickets a day arrive the same way and get routed the same way, but somebody has to read each one and decide what it’s about. That somebody can be an AI, inside a workflow: the structure stays deterministic, and the judgment happens at one visible step in the middle.
One part of this question people tend to skip: when do the decisions get made? There’s a big difference between an AI that drafts a reply for a human to approve and an AI that sends the reply itself. If a human needs to approve things, that checkpoint is part of your process, and you want a structure that makes it visible.
And if AI is making decisions inside something that runs on its own, you also need the things that make AI dependable in production: evals to know how often it’s right, guardrails for when it’s wrong, and logs that show you what it decided and why. Claude Code will happily build all of that for you, but operating it day after day is a different job altogether.
The third question sounds simple, and I’ve found it changes the answer more often than any other.
If it’s just you, it will stay just you, and you don’t care if it fails, then almost nothing else matters. Nobody else needs to read it, so it doesn’t matter that generated code is hard for others to follow. Pick whatever you’re fastest with and move on. (If you do care when it fails, that’s question 5, and it can change your answer even when you’re working alone.)
The moment other people enter, things change. I’d separate the people into three roles, because they need different things:
  • Who builds it.
    If the builder is a developer, every option is available to them. If the builder is a marketer or an ops person, plain-English building (a pure agent, or Claude Code driving n8n through the MCP server) is what makes them a builder at all.
  • Who maintains it.
    Six months from now, an API changes or a prompt needs adjusting. If the person fixing it is not the person who built it, they need to be able to open the thing and understand it. A visual workflow can be read by somebody who could never have written the code version of it.
  • Who uses it and changes it.
    This is a higher bar than understanding. Can a non-technical teammate swap a credential, edit a prompt, or change a schedule on their own? If every small change goes through one technical person, that person becomes the bottleneck for the whole team, and in my experience they end up resenting the automation they built.
There’s also the question of what happens when the builder leaves. A workflow that others can open and follow survives the handover. From what we’ve seen, custom code usually doesn’t; it keeps running until the day it breaks, and then nobody wants to touch it.
This is the question the demos skip.
Every automation demo ends at the moment the thing works once. If you’re building something that needs to keep working, most of the work comes after you finish building version 1.0, so it’s worth walking through what “running reliably” includes.
Where does it run?
An agent session runs while your laptop is open. A script runs wherever you put it, which means you now own a server, a cron job, or a deployment. A workflow runs on your n8n instance, and deploying it means clicking publish.
There’s also the question of whose computers it runs on: is a cloud service even an option for you, or does this need to run in a private environment, on servers you control? This is the reason self-hosting n8n matters so much to a lot of companies.
When does it run?
If something needs to happen when a customer submits a form, something has to be listening around the clock. An AI model’s API is call and response; it doesn’t listen. Whatever you build needs a layer that catches events and starts the work, whether you build that layer yourself or get it included.
At what scale?
I mean two different things by this:
  • How often does it run? A deterministic workflow that runs 500 times a day costs pennies, and the same job costs a lot more if an AI reasons through it 500 times. At volume, you want the tokens spent at build time and the runs to be as close to free as possible.
  • How many processes are you dealing with overall? Is this your first automation, or one of a hundred? Once you have dozens of automations running in parallel, you need one place that shows all of them, with logs and a UI, where you can see what ran, what failed, and rerun a failure after you fix it.
From what I’ve seen, this is one of the biggest reasons companies standardize on an orchestration layer like n8n: they need to manage hundreds of automations without it becoming a maintenance nightmare.
And reliably?
Things will fail. APIs time out, services rename fields, vendors have outages. Reliably means retries, error handling, alerts when something needs a human, and version history for when a change makes things worse.
You can definitely build all of this around your own code, and if you already have that infrastructure, that changes your answer. Most people don’t, and rebuilding it for every automation is how a two-day project becomes a two-month one.
The last question chronologically, but it can override all the others.
Eventually, something will go wrong.
The question to ask up front is: what’s the cost when that happens?
At one end of the spectrum, there’s the hobbyist building something for themselves on a spare VPS.
Nothing is connected to money, no customer data is involved, and the worst case is rebuilding. If that’s you, your risk tolerance can be close to unlimited, and speed should win every trade-off. Use whatever gets you there fastest.
At the other end, you’re at a regulated company, like a bank, where an automation touches customer data or has monetary consequences.
Now the questions multiply:
What can this thing do: read and report, or send and delete? Can a mistake be reversed? Will a failure be silent, or will somebody know within minutes? Where do the credentials live, and who can see them? How long does security review take, and will they approve something they can’t inspect?
I’d also point out that AI raises the stakes here. The less you can see of what the AI did and why, the higher your risk, whatever tool you’re using. As consequences grow, you need a solution where AI’s decisions are visible, logged, and bounded: an AI step inside a workflow you can audit, rather than an open-ended agent holding all of your keys.
In my experience, this whole question comes down to this:
Velocity vs risk tolerance
When the downside is small, velocity should win, and it usually points to Claude Code. As the downside grows, staying in control starts to outrank speed, and it usually points to n8n. Most teams sit somewhere in the middle, which is a big part of why the answer keeps being “both.”
Putting it all together
If you’ve answered the questions above, here’s a simple way to read your answers:
  1. Mostly landed on the “just me, low stakes, lots of judgment, runs while I watch” side?
    Use Claude Code by itself and don’t overthink it.
  2. Mostly landed on the “other people, recurring, unattended, consequences” side?
    Build it as an n8n workflow, and use Claude Code (or Codex, or whatever coding agent you prefer) with the MCP server to do the building.
  3. Split down the middle? Split the work:
    Let the deterministic, recurring part be a workflow, and let the judgment-heavy part be an agent or an AI step inside of it.
A few examples make this concrete:
  • A bank automating a customer-facing process.
    Regulated, team-maintained, unattended, and mistakes cost money and trust. This is an n8n workflow with every AI step logged and bounded, and it was never a close call.
  • A developer building their own app or product.
    Custom logic, code is the natural material, and n8n has no role to play. Claude Code, full speed, and that’s fine. Not everything needs a workflow.
  • Writing an article, doing research.
    One-off, judgment throughout, and you’re in the loop the whole time. A pure agent session; a workflow would just add overhead.
  • A support inbox handling 500 tickets a day.
    Recurring and unattended, with a judgment call inside every run and a team that needs to see what happened. A workflow with an AI step in the middle, built and maintained through Claude Code and the MCP server.
  • An agency running 200 automations for clients.
    Whatever any single automation looks like, the fleet decides this one: you want one orchestration layer, with logs and a UI that teammates and clients can open. Build each workflow with Claude Code; run all of them in n8n.
So, Claude Code or n8n?
I hate to admit it, but it took me a while to realize this question was really up for debate.
I use both of them very heavily (as do many of my colleagues at n8n) so I probably have a better understanding of the n8n landscape than most people :)
So for me personally there’s never been any question of which tool to use under what circumstances. When the n8n MCP server was released (with ability to build workflows) using them together also became part of my standard operating procedure.
So instead of a direct answer, let me leave you with a suggestion for each side.
If you’re already using both n8n and Claude Code (or Codex, etc) connect them now. Connect Claude Code to your n8n instance MCP server and let it do the building with you. I think it will change how you build.
And if you’re living mostly in Claude Code, then the next time you build something that has to run every day without you, try building it as an n8n workflow instead of another script. You’ll know within an hour whether it works for you, and you’ll have a new tool under your belt.
At the end of the day, it’s simply about using the right tool for the job, not about tool A vs tool B.
Share with us
SHARE
