If you’re building an AI app for production, you’ll eventually end up thinking about fine-tuning versus RAG. Should you give your model access to external knowledge at runtime or retrain it to behave differently?
The answer depends on the problem you’re trying to solve. In this guide, you’ll learn how RAG and fine-tuning work, where each approach excels, and why RAG became a go-to solution for most teams.
What’s RAG and how does it work?
Retrieval-augmented generation (RAG) gives a large language model (LLM) access to information that wasn’t included in its training data. Instead of relying solely on what the model already knows, a RAG system retrieves relevant information from an external source like a vector database, documentation plain-text files, or specialized knowledge-graph base. The system includes that context in the prompt before the model generates a response.
Because the knowledge lives outside the model, you can update information without retraining the model. That’s why many teams use RAG for applications that need access to large, frequently changing, or proprietary datasets like internal copilots or customer support assistants.
What’s fine-tuning and how does it work?
Fine-tuning adapts an existing LLM by training it on additional examples. Instead of supplying information at runtime, you teach the model new behaviors by updating its weights using domain-specific data.
This approach first appeared when the long-context LLMs were not widely available and tokens were relatively expensive. It helped improve how a model responded with zero-shot prompting. For example, you might fine-tune a model to follow a specific writing style, generate more consistent outputs, or perform better on specialized tasks in areas like healthcare or finance. Once training is complete, the model can apply those learned patterns without requiring additional context for every request.
Nowadays fine-tuning is less common compared to RAG for several reasons, but remains a viable option for niche use-cases.
Retrieval-augmented generation vs. fine-tuning: What’s the difference?
The main difference between LLM RAG versus fine-tuning lies in where adaptation happens. RAG keeps the underlying model unchanged and supplies relevant information at runtime. Fine-tuning changes the model itself through additional training. That distinction has important implications for everything from maintenance and governance to cost and performance.
In practice, the choice often comes down to the problem you’re solving. If your model needs access to current information, proprietary documents, or a large body of knowledge that changes frequently, RAG is usually the better fit.
If the challenge is getting the model to respond more consistently or perform better on specialized tasks, fine-tuning may deliver better results if done correctly. However, the same task is doable via RAG too, as relevant examples can be retrieved in a similar way and passed to the LLM via a few-shot prompting technique.
Cost and latency tradeoffs at scale
RAG and fine-tuning shift costs to different parts of the AI lifecycle. With RAG, most costs occur in the execution . You need to generate embeddings, store them in a vector database, and retrieve relevant context before the model can respond. This makes it easy to keep knowledge up to date, but it adds infrastructure costs and an extra retrieval step to every request. Good retrieval could require additional engineering efforts, i.e. mixing sparse and dense vectors + re-ranking to achieve the optimal retrieval results.
Fine-tuning front-loads costs into data preparation and training. Creating a set of quality examples is a non-trivial task and can potentially deteriorate a model's results. Frontier cloud models don’t support fine-tuning in general, and some of the hosted models are dropping fine-tuning features. On a positive side, smaller open-weight LLMs, once fine-tuned, can often respond without retrieving external context or extensive prompting. This can reduce runtime overhead and improve response times.
The tradeoff is straightforward: RAG is typically easier and cheaper to update, while fine-tuning can be more efficient at inference. The choice depends on whether you're solving a knowledge problem or a behavior problem and which LLMs you need.
When to use RAG vs. fine-tuning
The easiest way to choose between RAG and fine-tuning is to identify the root cause of the problem. If your model lacks access to the right information, RAG is usually the better place to start. If it has the information but still produces inconsistent or low-quality outputs, fine-tuning may be a better solution, especially when using smaller LLMs.
Choose RAG when:
- Your knowledge changes frequently: RAG lets you update product documentation, policies, pricing information, and other knowledge sources without retraining the model.
- Factual accuracy matters: RAG can retrieve information from trusted sources at runtime, reducing the risk of outdated responses.
- You need source traceability: Responses can link back to the documents used to generate them.
- Your knowledge base is large: Retrieving relevant information is more practical than trying to encode everything into the model.
- Your cost-model allows few-shot prompting: Altering the model’s behavior can be achieved with a set of frontloaded examples, but requires more tokens.
Choose fine-tuning when:
- You need more consistent outputs: The model struggles to follow specific formats, instructions, or response patterns.
- You want a particular tone or style: Responses need to reflect your brand and communication standards.
- You're solving specialized tasks: The base model doesn't perform reliably enough on your specific use case.
- You need stronger domain-specific reasoning: The model needs to apply concepts, terminology, or decision-making patterns that aren't well represented in its original training data.
Combining RAG and fine-tuning
RAG and fine-tuning aren't mutually exclusive. While RAG is suitable for most LLMs and generally easier to create, combining it with a fine-tuned model can further improve output quality.
In a hybrid architecture:
- Fine-tuning improves behavior: Train the local model to follow a specific tone, format responses consistently
- RAG improves knowledge: Retrieve current, relevant information at runtime instead of relying on what the model learned during training.
- Together, they deliver better results: When both RAG and fine-tuning are set correctly, the model knows how to respond and has access to the information it needs to generate accurate answers.
A customer support assistant is a good example. A private self-hosted fine-tuned model can learn your company's communication style and support processes. A RAG pipeline retrieves the latest product documentation, policies, and troubleshooting guides before a response is generated.
This hybrid approach can work well at scale, with initial fine-tuning efforts paying off in the long run. Instead of adding the same context over and over again, it is possible to fine-tune LLM only on the “stable” content and leave RAG for the “dynamic” knowledge that changes day to day. Platforms like n8n make it possible to use this combination.
Researchers are also exploring ways to bring these techniques even closer together. One emerging approach is retrieval-augmented fine-tuning (RAFT). This fine-tunes models on examples that already include retrieved context, helping them learn how to use external information more effectively.
How to build RAG and fine-tuning workflows with n8n
Once you choose an approach, the next step is implementation. n8n gives you one place to build and refine RAG and fine-tuning workflows. You can design, test, and adjust each pipeline without switching tools or managing separate systems.
For RAG workflows, n8n provides the building blocks to ingest and retrieve knowledge. You can load documents, split them into chunks, generate embeddings, and store them in vector databases like Pinecone or Supabase. From there, AI Agent nodes can then retrieve relevant context and pass it to an LLM at query time.
For fine-tuning workflows, n8n can store fine-tuning example datasets and connect to local fine-tuned models via Ollama. That means you can work with fine-tuned model endpoints alongside standard model deployments without introducing additional orchestration tools.
As requirements evolve, you can combine both approaches in the same workflow. Conditional branching makes it possible to route requests between RAG pipelines, direct model calls, and fine-tuned models based on the task at hand. Execution history provides visibility into retrieval quality, prompts, and model outputs, which makes it easier to test and refine AI systems over time.
Choosing the right approach for your LLM application
For most use cases, RAG has proven to be more cost-effective and easier to implement compared to fine-tuning, but both complement each other when adapting LLMs to real-world applications. Choose based on your requirements today and how those requirements might change over time.
Many teams debating LLM fine-tuning versus RAG start with the latter because it's easier to update and experiment with. Others turn to fine-tuning when they need more specialized behavior on self-hosted infrastructure. As AI systems mature, it's possible to incorporate both approaches into the same architecture.
That's where orchestration becomes important. With support for RAG pipelines, direct model calls, fine-tuned model endpoints, AI agents, and workflow orchestration, n8n gives teams a single place to build, test, and evolve AI systems without managing separate tools for each approach.
